Alienware 15 R3 Hard Drive Replacement
    1. Alienware 15 R3 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 Alienware 15 R3 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 Alienware 15 R3 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
      • Find the Power option in the start menu and click Shut Down to turn off your Alienware 15 R3.
      • Wait a few seconds until all the computer's lights are off.
      • Unplug the power supply.
      Ask FixBot
    2. Alienware 15 R3 Hard Drive Replacement: step 2, image 1 of 3 Alienware 15 R3 Hard Drive Replacement: step 2, image 2 of 3 Alienware 15 R3 Hard Drive Replacement: step 2, image 3 of 3
      • Remove the six M2.5x13 screws from along the side edge of the base cover.
      • Loosen the top middle captive screw on the base cover.
      • It should not be removed, just loosen it so the bottom case can be removed.
      • Remove the base cover carefully.
      • Save these screws for later.
      Ask FixBot
    3. Alienware 15 R3 Hard Drive Replacement: step 3, image 1 of 3 Alienware 15 R3 Hard Drive Replacement: step 3, image 2 of 3 Alienware 15 R3 Hard Drive Replacement: step 3, image 3 of 3
      • Remove the two M3x3 screws that are holding the bracket and the one M2.5x8 screw holding the hard drive assembly.
      • Remove the hard drive from the laptop.
      Ask FixBot
    4. Alienware 15 R3 Hard Drive Replacement: step 4, image 1 of 2 Alienware 15 R3 Hard Drive Replacement: step 4, image 2 of 2
      • Prior to reassembly, clean the dust from the fans as circled in the picture if needed.
      • Put the bottom plate back on your laptop and secure it with the screws removed previously.
      Ask FixBot
    5. Alienware 15 R3 Hard Drive Replacement: step 5, image 1 of 1
      • Your Alienware 15 R3 is ready to roll!
      Ask FixBot
By removing the HDD, the Blue Screen of Death should not occur anymore when booting the laptop. Please note that the volume of storage on your computer may change.
2 other people completed this guide.
Yutong Yin
166 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 69
All Time: 2,019
