Alcatel OneTouch Pop Icon Camera Replacement
  1. Alcatel OneTouch Pop Icon Camera Replacement, Battery: step 1, image 1 of 1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Camera Replacement: step 2, image 1 of 2 Alcatel OneTouch Pop Icon Camera Replacement: step 2, image 2 of 2
    • Use your thumbnail to lift the battery from the phone.
  3. Alcatel OneTouch Pop Icon Camera Replacement, Interior Back Panel: step 3, image 1 of 1
    • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
    • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
  4. Alcatel OneTouch Pop Icon Camera Replacement: step 4, image 1 of 1
    • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
    • Make sure all of the clips come undone when you pry the seam loose.
  5. Alcatel OneTouch Pop Icon Camera Replacement, Camera: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to gently lift the tab free from the motherboard.
  6. Alcatel OneTouch Pop Icon Camera Replacement: step 6, image 1 of 1
    • Gently lift the camera away from the motherboard.
3 Comments
Hi I just noticed last night that the lense cover for my camera has fallen off any ideas on how to replace it?
Phoeras Mortisangelina - Reply
Do we put a new camera or that old one
Sareen Lata - Reply
Urgently needed
Sareen Lata - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 705
