Alcatel Fierce 4 Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
63
All Time:
571
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Alcatel Fierce 4 Camera is not working well? black spots? Might be the time for a replace. Don’t waste your money and let someone do it for you. You can do it using this guide
Tools
    1. Alcatel Fierce 4 Camera Replacement, Battery: step 1, image 1 of 1
      • Using a plastic opening tool, pry the back cover off of the phone.
      Ask FixBot
    2. Alcatel Fierce 4 Camera Replacement: step 2, image 1 of 2 Alcatel Fierce 4 Camera Replacement: step 2, image 2 of 2
      • Remove the seventeen Phillips #000 screws from the mid-frame.
      Ask FixBot
    3. Alcatel Fierce 4 Camera Replacement: step 3, image 1 of 1
      • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
      Ask FixBot
    4. Alcatel Fierce 4 Camera Replacement: step 4, image 1 of 2 Alcatel Fierce 4 Camera Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to disconnect all of the cables on the motherboard.
      • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
      Ask FixBot
    5. Alcatel Fierce 4 Camera Replacement: step 5, image 1 of 1
      • Remove the motherboard from the phone.
      Ask FixBot
    6. Alcatel Fierce 4 Camera Replacement: step 6, image 1 of 1
      • Carefully pry up the battery with a plastic opening tool, or your hands.
      Ask FixBot
    1. Alcatel Fierce 4 Camera Replacement, Camera: step 7, image 1 of 2 Alcatel Fierce 4 Camera Replacement, Camera: step 7, image 2 of 2
      • Remove the rubber piece surrounding the camera.
      Ask FixBot
    2. Alcatel Fierce 4 Camera Replacement: step 8, image 1 of 2 Alcatel Fierce 4 Camera Replacement: step 8, image 2 of 2
      • Use a plastic opening tool to pry up the camera.
      Ask FixBot
Rawan
650 Reputation
4 Guides authored
USF Tampa, Team S1-G2, Cagle Spring 2018 Member of USF Tampa, Team S1-G2, Cagle Spring 2018
USFT-CAGLE-S18S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 63
All Time: 571
