Introduction
Replacing the battery on the Alcatel A30 is supposed to be impossible. Dire warnings of fire are given, but in fact it is fairly easy.
Remove the back of the phone with a fingernail or spudger. Remove the SD card and SIM.
Remove the 13 Philipps type screws holding the inner cover in place. The YouTube video (https://www.youtube.com/watch?v=aALEwr_x...) indicated shows the procedure for a similar phone. Note that the four corner screws are longer than the others.
Now the battery is exposed, but is glued in place by two glue strips. I tried pulling these, as one does for an iPhone, but they broke, so I used an old-fashioned razor blade (flexible) to start with, and then a sharp ceramic knife (a paring knife would be ideal) to cut the glue after prizing up the battery somewhat.
Reassemble by reversing the disassembly procedure, taking care to make sure the inner cover fits snugly in place all round - one corner has a tendency not to snap down properly. Make sure the long screws go into the four corner holes. Switch on, charge up and away you go - my battery showed 50% charge before charging.
