Replace the battery
  1. Replace the battery, Remove the case screws: step 1, image 1 of 1
    • Close the laptop, place it on its lid, and align it as shown in the image
    • There are three different screw lengths:
    • 4 x PH1 12 mm (orange)
    • 3 x PH1 10 mm (yellow)
    • 4 x PH1 7 mm (green)
    • The screws must be reinstalled in the correct position later, otherwise something can be damaged.
    • Take out the screws and sort them by length.
  2. Replace the battery, Remove the keyboard: step 2, image 1 of 1
    • Turn the device over and open it.
    • Once the keyboard is detached, you must remove the 4 ribbon cables before you can remove the keyboard!
    • Carefully insert the Jimmy into the gap between the case and the keyboard at the lower right corner of the keyboard.
    • From this position, work your way forward by levering alternately to the left and up until the keyboard is loose on the case.
  3. Replace the battery, Unplug the keyboard cable and remove the keyboard: step 3, image 1 of 2 Replace the battery, Unplug the keyboard cable and remove the keyboard: step 3, image 2 of 2
    • There are 4 cables that must be removed!
    • Carefully open the keyboard under the touchpad, move it in the direction of the screen.
    • Use the spudger to lift the black lock on the ribbon cable and carefully pull out the cable. Repeat this for each one of the four ribbon cables.
  4. Replace the battery, Disconnect the battery: step 4, image 1 of 3 Replace the battery, Disconnect the battery: step 4, image 2 of 3 Replace the battery, Disconnect the battery: step 4, image 3 of 3
    • Locate the battery connector.
    • Carefully slide the metal clip (marked blue in the picture) upwards to unlock the connector.
    • Use the spudger to lift the white connector upwards.
  5. Replace the battery, Remove screws: step 5, image 1 of 1
    • Remove the two screws (PH1 - 8 mm)
  6. Replace the battery, Remove the battery: step 6, image 1 of 2 Replace the battery, Remove the battery: step 6, image 2 of 2
    • Remove the battery by lifting it upwards.
Now you can insert the new battery and then follow the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
buntstift
1,293 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 41
All Time: 248
