With the machine on, go to the Quick Settings in the Home Menu.
Select the "Level Table" option.
Select "Home XYZ" so that the head goes to the starting position.
The leveling should be performed on the 4 points of the table, as shown in the figure.
Select the "Set P1" option to level the table height at the first point.
The nozzle should be slightly away from the glass (thickness of a sulphite sheet).
To bring the table closer to the nozzle, turn the rosette clockwise.
To move the table away from the spout, rotate the rosette counterclockwise.
Repeat the procedure for adjusting P1 for the other points.
Ready! Your table is level!
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
