Repairing AirPort Extreme A1521 Battery
  1. Repairing AirPort Extreme A1521 Battery, Internal Structure: step 1, image 1 of 2 Repairing AirPort Extreme A1521 Battery, Internal Structure: step 1, image 2 of 2
    • Using a metal spudger, gently pry the cover off the bottom of the device.
  2. Repairing AirPort Extreme A1521 Battery: step 2, image 1 of 2 Repairing AirPort Extreme A1521 Battery: step 2, image 2 of 2
    • Four black internal wires, three thin and one thick, are connected to the logic board: three by small end clips and one by a larger end clip. Handle the clips gently; they break easily.
    • To detach the small clips from the connectors, place the flat end of the plastic spudger underneath the clip and gently lever it away from the center of the device.
    • To detach the large clip from its connector, place the flat end of the spudger on the clip and lever it upward out of the connector.
  3. Repairing AirPort Extreme A1521 Battery: step 3, image 1 of 3 Repairing AirPort Extreme A1521 Battery: step 3, image 2 of 3 Repairing AirPort Extreme A1521 Battery: step 3, image 3 of 3
    • Using two fingers, pinch the power supply wire and gently lift it upward. Move it away from the metal plate.
    • Next, unscrew the four 3.3mm T8 Torx screws and remove the metal plate.
    • The metal plate fits snugly into the gap. To reassemble the device, push the rounded edge of the plate into the gap first. This will wedge the gap open so that you can fit the rest of the plate into its proper place.
  4. Repairing AirPort Extreme A1521 Battery: step 4, image 1 of 1
    • Remove the T8 Torx screwdriver head and replace it with the 60 mm extension; then, add the T9 Torx head.
    • Loosen, but do not remove the two screws at the bottom of the 1.2-inch wide gap in the middle of the internal structure.
    • These screws are spring-loaded and will stay in the device, even when loosened; however, it is still possible for them to be fully removed. Be careful to only partially loosen them.
  5. Repairing AirPort Extreme A1521 Battery: step 5, image 1 of 2 Repairing AirPort Extreme A1521 Battery: step 5, image 2 of 2
    • Using only your fingers, gently compress the internal structure and pull evenly upward to remove it from the white case.
    • When you put the internal structure back into the case, gently compress it, and lower it most of the way into the case. Stop lowering it when the top port has just entered the case. Now push the two sides of the internal structure outward against the sides of the case.
    • Finish lowering the internal structure the rest of the way into the case. The ports should be lined up with the openings in the case and should be flush against the sides of the case.
  6. Repairing AirPort Extreme A1521 Battery, Logic Board: step 6, image 1 of 1
    • Eight 10.25 mm T8 Torx screws secure the heat sink to the logic board. Unscrew all eight screws.
    • Remove the heat sinks from the logic board.
  7. Repairing AirPort Extreme A1521 Battery: step 7, image 1 of 1
    • Wedge the corner of the plastic spudger under one of the silver antenna clips. Gently lever the tip of the spudger away from the logic board to detach the antenna clip.
    • Repeat this for all six clips.
  8. Repairing AirPort Extreme A1521 Battery: step 8, image 1 of 2 Repairing AirPort Extreme A1521 Battery: step 8, image 2 of 2
    • To release the logic board, unscrew four 5.5 mm T8 Torx screws from the internal structure.
    • Remove the logic board from the internal structure.
  9. Repairing AirPort Extreme A1521 Battery, Battery: step 9, image 1 of 1
    • Rotate the logic board so that the white ports face downward.
  10. Repairing AirPort Extreme A1521 Battery: step 10, image 1 of 2 Repairing AirPort Extreme A1521 Battery: step 10, image 2 of 2
    • Wedge the flat end of the plastic spudger between the battery and its casing.
    • To pop the battery out, firmly lever the spudger upwards.
Tarun
238 Reputation
1 Guide authored
Cal Poly, Team 4-26, Amido Fall 2013 Member of Cal Poly, Team 4-26, Amido Fall 2013
CPSU-AMIDO-F13S4G26
5 Members
18 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 50
All Time: 6,811
