AirPods Pro 3 Ear Tip Replacement
    1. AirPods Pro 3 Ear Tip Replacement, Ear Tip: step 1, image 1 of 1
      • Wash your hands and work on a clean, dry surface.
      • Ensure your AirPods are powered off or in their charging case.
      Ask FixBot
    2. AirPods Pro 3 Ear Tip Replacement: step 2, image 1 of 1
      • Hold one AirPod firmly by the stem.
      • Pinch the silicone ear tip near its base and gently pull straight away until it “pops” off.
      • Don’t twist too hard — the connector ring may crack.
      Ask FixBot
    3. AirPods Pro 3 Ear Tip Replacement: step 3, image 1 of 2 AirPods Pro 3 Ear Tip Replacement: step 3, image 2 of 2
      • Locate the oval connector ring inside the new tip.
      • Line it up with the oval post on the AirPod.
      • Push until you hear a soft “click.”
      • Gently tug to confirm it’s locked in place.
      Ask FixBot
    4. AirPods Pro 3 Ear Tip Replacement: step 4, image 1 of 2 AirPods Pro 3 Ear Tip Replacement: step 4, image 2 of 2
      • insert the AirPods and run the Fit Test in iOS settings if available.
      • Adjust or reseat as needed.
      • Follow the same process for the second AirPod.
      Ask FixBot
Enjoy your new ear tips!
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 31
Past 7 Days: 250
Past 30 Days: 816
All Time: 3,201
