This teardown is not a repair guide. To repair your AEG ClassicSilence, use our service manual.
    1. AEG ClassicSilence Teardown, Removing the plastic covers: step 1, image 1 of 3 AEG ClassicSilence Teardown, Removing the plastic covers: step 1, image 2 of 3 AEG ClassicSilence Teardown, Removing the plastic covers: step 1, image 3 of 3
      • First, remove the hose and take out the bag. Then, remove the rear cover for the exhaust filter and the filter itself. Also, remove the filter from the bag compartment.
      Ask FixBot
    2. AEG ClassicSilence Teardown, Remove the slider: step 2, image 1 of 2 AEG ClassicSilence Teardown, Remove the slider: step 2, image 2 of 2
      • The slider can be removed by inserting a flathead screwdriver into the small slots to release the locking mechanism. The pictures were taken during reassembly, so the handle is already missing.
      Ask FixBot
    3. AEG ClassicSilence Teardown, Unscrew the cover: step 3, image 1 of 3 AEG ClassicSilence Teardown, Unscrew the cover: step 3, image 2 of 3 AEG ClassicSilence Teardown, Unscrew the cover: step 3, image 3 of 3
      • Now the top cover can be unscrewed. Removing it is a bit fiddly because of the handle. Reassembly is much easier, as the handle can be removed for this purpose.
      Ask FixBot
    4. AEG ClassicSilence Teardown: step 4, image 1 of 3 AEG ClassicSilence Teardown: step 4, image 2 of 3 AEG ClassicSilence Teardown: step 4, image 3 of 3
      • Remove the plastic cover from the cable guide and release the screws, then the inner part can be removed from the shell. Also, remove the cable reel.
      Ask FixBot
    5. AEG ClassicSilence Teardown, Exposing the motor: step 5, image 1 of 3 AEG ClassicSilence Teardown, Exposing the motor: step 5, image 2 of 3 AEG ClassicSilence Teardown, Exposing the motor: step 5, image 3 of 3
      • Now the housing screws can be easily removed, and the motor as well as the insulation materials can be taken out.
      Ask FixBot
Franz Ferdinand
141 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 48
All Time: 1,480
