Community-Contributed Guide
Introduction
Go to step 1 ↓The Clean Air CA-604B air humidifier has an internal buzzer that beeps every time the user presses a button or when it’s out of water. This is very a very annoying behaviour and I couldn’t find a way to make it shut up.
Unfortunately, the buzzer is soldered on the display’s mainboard so it requires a bit of work to take the whole thing apart and unsolder the noisy component.
Do this at your own risk!
This will most likely void your warranty!
Take out the water tank
Remove the 7 screw covers using a flat screwdriver/sharp blade
Remove the 7 screws using a Phillips screw driver
Remove the 6 screw covers
Remove the two rubber covers (front feet). They're glued using double adhesive tape.
Remove the screws revealed by removing the covers above
Remove the bottom cover
Remove the three screws
Detach the white plug (press on it for releasing it)
Slide the top part about 1cm to detach it from the bottom one
Release the two screws
Using a prying tool remove the top plastic cover
Remove the screws that hold the mainboard
Locate the black buzzer/speaker
Flip the mainboard and using a soldering iron remove the component. Add a bit of solder on top of the existing one to make detaching easier
The source of 4AM noise is now removed!
After bolting the mainboard, make sure your route the wire as indicated by the red line in the picture (the wire is quite short)
Reassemble the device in reverse order
Before trying out the new silent device, make sure you add the water tank (as the panel doesn't seem to work properly without water)
Enjoy your quiet sleep!
