Disassemble the battery for airpods
  1. Disassemble the battery for airpods, Disassemble the battery for airpods: step 1, image 1 of 3 Disassemble the battery for airpods, Disassemble the battery for airpods: step 1, image 2 of 3 Disassemble the battery for airpods, Disassemble the battery for airpods: step 1, image 3 of 3
    • This is the first part of the process of replacing the battery with the damaged airpods, mainly to see the internal structural details close-up, to prepare for the complete disassembly below.
  2. Disassemble the battery for airpods: step 2, image 1 of 3 Disassemble the battery for airpods: step 2, image 2 of 3 Disassemble the battery for airpods: step 2, image 3 of 3
    • This part is to disassemble the details of the charging contact parts at the bottom of the battery.
  3. Disassemble the battery for airpods: step 3, image 1 of 3 Disassemble the battery for airpods: step 3, image 2 of 3 Disassemble the battery for airpods: step 3, image 3 of 3
    • Continue below
  4. Disassemble the battery for airpods: step 4, image 1 of 3 Disassemble the battery for airpods: step 4, image 2 of 3 Disassemble the battery for airpods: step 4, image 3 of 3
    • This part is to try to remove the battery after heating
  5. Disassemble the battery for airpods: step 5, image 1 of 3 Disassemble the battery for airpods: step 5, image 2 of 3 Disassemble the battery for airpods: step 5, image 3 of 3
    • It can be seen that when the first attempt to practice disassembling the battery, the signal antenna components have been pulled out, resulting in damage to the antenna components.
  6. Disassemble the battery for airpods: step 6, image 1 of 3 Disassemble the battery for airpods: step 6, image 2 of 3 Disassemble the battery for airpods: step 6, image 3 of 3
    • Here you can see that the negative pole of the battery is connected from the top to the bottom of the charge, and the inside of the antenna part is glued to the battery.
  7. Disassemble the battery for airpods: step 7, image 1 of 3 Disassemble the battery for airpods: step 7, image 2 of 3 Disassemble the battery for airpods: step 7, image 3 of 3
    • Close-up of the original parts of the airpods after the disassembly of the battery, for the complete disassembly of the bottom to make reference
  8. Disassemble the battery for airpods: step 8, image 1 of 3 Disassemble the battery for airpods: step 8, image 2 of 3 Disassemble the battery for airpods: step 8, image 3 of 3
    • Well, start the official airpods battery replacement and disassembly. After heating, use a scalpel to slide open the bottom charging microphone unit.
  9. Disassemble the battery for airpods: step 9, image 1 of 3 Disassemble the battery for airpods: step 9, image 2 of 3 Disassemble the battery for airpods: step 9, image 3 of 3
    • After taking out, pay attention to the internal measurement microphone cable, don't break it, gently open it and drop it into the debonding agent.
  10. Disassemble the battery for airpods: step 10, image 1 of 3 Disassemble the battery for airpods: step 10, image 2 of 3 Disassemble the battery for airpods: step 10, image 3 of 3
    • At the same time, the fuel for the Zippo lighter is prepared for the next foaming dissolution, and then the inner glue is cleaned.
  11. Disassemble the battery for airpods: step 11, image 1 of 3 Disassemble the battery for airpods: step 11, image 2 of 3 Disassemble the battery for airpods: step 11, image 3 of 3
    • Prepare the required disassembly and soldering tools, fix the airpods, add a small amount of solder for faster heat conduction, and more convenient to remove the bottom battery cable at the bottom.
  12. Disassemble the battery for airpods: step 12, image 1 of 3 Disassemble the battery for airpods: step 12, image 2 of 3 Disassemble the battery for airpods: step 12, image 3 of 3
    • The following is a close-up of the part after removing the negative pole of the battery.
  13. Disassemble the battery for airpods: step 13, image 1 of 3 Disassemble the battery for airpods: step 13, image 2 of 3 Disassemble the battery for airpods: step 13, image 3 of 3
    • Change direction, continue to tilt the lower cable, and solder the battery positive with a soldering iron.
  14. Disassemble the battery for airpods: step 14, image 1 of 3 Disassemble the battery for airpods: step 14, image 2 of 3 Disassemble the battery for airpods: step 14, image 3 of 3
    • Close-up of battery under positive electrode
  15. Disassemble the battery for airpods: step 15, image 1 of 3 Disassemble the battery for airpods: step 15, image 2 of 3 Disassemble the battery for airpods: step 15, image 3 of 3
    • Use a syringe to inject the glue around the outside of the battery, waiting for the rubber foam to soften
  16. Disassemble the battery for airpods: step 16, image 1 of 3 Disassemble the battery for airpods: step 16, image 2 of 3 Disassemble the battery for airpods: step 16, image 3 of 3
    • Use a pair of tweezers to shake the antenna on the outside of the battery to the left and right, then drop the debonding agent, and finally insert a thin plastic piece into the middle of the battery and the inside of the antenna, up and down, to loosen the battery and the antenna.
  17. Disassemble the battery for airpods: step 17, image 1 of 3 Disassemble the battery for airpods: step 17, image 2 of 3 Disassemble the battery for airpods: step 17, image 3 of 3
    • Finally, heat the upper part around the outer casing of the earphone with a heat gun to soften the filling rubber on the inside. After heating, drip the sol and Zippo again. Finally, use the hook and pliers to slowly pull the battery out.
  18. Disassemble the battery for airpods: step 18, image 1 of 3 Disassemble the battery for airpods: step 18, image 2 of 3 Disassemble the battery for airpods: step 18, image 3 of 3
    • Finally finally the battery is perfectly removed, you can see the bottom of the charging and microphone parts cable and antenna cable in the airpods
  19. Disassemble the battery for airpods: step 19, image 1 of 3 Disassemble the battery for airpods: step 19, image 2 of 3 Disassemble the battery for airpods: step 19, image 3 of 3
    • Be prepared to replace the battery removed from the previously damaged airpods, and prepare the sticker on the back of the adhesive to cut the appropriate size.
  20. Disassemble the battery for airpods: step 20, image 1 of 3 Disassemble the battery for airpods: step 20, image 2 of 3 Disassemble the battery for airpods: step 20, image 3 of 3
    • Insert the cut piece of paper into the middle of the battery cable and the antenna cable to facilitate the battery to reduce friction.
  21. Disassemble the battery for airpods: step 21, image 1 of 3 Disassemble the battery for airpods: step 21, image 2 of 3 Disassemble the battery for airpods: step 21, image 3 of 3
    • Then use the damaged battery core that was removed before, press the loaded battery down, and finally solder the positive electrode of the battery. Be careful not to solder for a long time, and solder it quickly, otherwise it will damage the battery.
  22. Disassemble the battery for airpods: step 22, image 1 of 3 Disassemble the battery for airpods: step 22, image 2 of 3 Disassemble the battery for airpods: step 22, image 3 of 3
    • Finally, the negative electrode of the battery is welded and stabilized with B-7000 glue, but to be more stable, it is recommended to use ab glue or epoxy glue.
  23. Disassemble the battery for airpods: step 23, image 1 of 3 Disassemble the battery for airpods: step 23, image 2 of 3 Disassemble the battery for airpods: step 23, image 3 of 3
    • Fix the glued airpods with the fixing clips, wait for the glue to solidify, or increase the temperature to accelerate the glue fixed line.
  24. Disassemble the battery for airpods: step 24, image 1 of 1
    • Install charging and test charging, play song control, Bluetooth signal connection test is stable, and finally can be used for at least three hours.
deng lei
3,043 Reputation
2 Guides authored
Past 24 Hours: 35
Past 7 Days: 259
Past 30 Days: 1,388
All Time: 47,002
