Air Conditioning Vent Replacement
    1. Air Conditioning Vent Replacement, Air Conditioning Vent Replacement: step 1, image 1 of 3 Air Conditioning Vent Replacement, Air Conditioning Vent Replacement: step 1, image 2 of 3 Air Conditioning Vent Replacement, Air Conditioning Vent Replacement: step 1, image 3 of 3
      • Measure and mark a rectangle around the damaged drywall area using the carpenter's pencil.
      • Set up a drop cloth underneath the work area, and a step ladder on top of the cloth for cleanliness and easy access to the work space as needed.
      • Wear goggles throughout this process. This work will result in drywall dust and insulation falling frequently, in addition to the risks of dropped tools.
      Ask FixBot
    2. Air Conditioning Vent Replacement: step 2, image 1 of 3 Air Conditioning Vent Replacement: step 2, image 2 of 3 Air Conditioning Vent Replacement: step 2, image 3 of 3
      • Push the jab saw into the ceiling.
      • Optionally, the utility knife may be used to start the puncture, and a hammer may be used to tap the saw into place.
      Ask FixBot
    3. Air Conditioning Vent Replacement: step 3, image 1 of 3 Air Conditioning Vent Replacement: step 3, image 2 of 3 Air Conditioning Vent Replacement: step 3, image 3 of 3
      • Saw through the drywall in the rectangle you have marked, and remove the drywall piece.
      • Insert furring strips to attach the replacement drywall to on top of the existing drywall and under any insulation.
      Ask FixBot
    4. Air Conditioning Vent Replacement: step 4, image 1 of 2 Air Conditioning Vent Replacement: step 4, image 2 of 2
      • Use the removed drywall to mark the outside area to cut on the drywall patch.
      • Cut along the marked line with the utility knife.
      • Bend the patch at the cut point, and use the utility knife again to cut through the paper on the other side.
      Ask FixBot
    5. Air Conditioning Vent Replacement: step 5, image 1 of 3 Air Conditioning Vent Replacement: step 5, image 2 of 3 Air Conditioning Vent Replacement: step 5, image 3 of 3
      • Cut the inside section out to match the vent measurements.
      Ask FixBot
    6. Air Conditioning Vent Replacement: step 6, image 1 of 2 Air Conditioning Vent Replacement: step 6, image 2 of 2
      • Put the patch into place.
      • If it does not fit cleanly, carefully mill down the edges that don't fit with the drywall saw.
      • Drill holes through the patch and furring strips.
      • Using the holes drilled as guides, insert wood screws to attach the patch to the furring strips.
      Ask FixBot
    7. Air Conditioning Vent Replacement: step 7, image 1 of 3 Air Conditioning Vent Replacement: step 7, image 2 of 3 Air Conditioning Vent Replacement: step 7, image 3 of 3
      • Drill holes for drywall anchors, and set the anchors with a hammer.
      • Screw the vent into place using the drywall anchors.
      Ask FixBot
    8. Air Conditioning Vent Replacement: step 8, image 1 of 3 Air Conditioning Vent Replacement: step 8, image 2 of 3 Air Conditioning Vent Replacement: step 8, image 3 of 3
      • Spackle between the drywall patch and the rest of the ceiling.
      Ask FixBot
    9. Air Conditioning Vent Replacement: step 9, image 1 of 2 Air Conditioning Vent Replacement: step 9, image 2 of 2
      • Sand the dried spackle until smooth and matching the rest of the ceiling.
      • Paint the patch to match as needed.
      Ask FixBot
After this process you'll have a repaired ceiling with vent attached, ready to paint.
Bellegante
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 152
All Time: 949
