Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: step 1, image 1 of 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: step 1, image 2 of 2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: step 2, image 1 of 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: step 2, image 2 of 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: step 2, image 3 of 3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: step 3, image 1 of 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: step 3, image 2 of 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: step 3, image 3 of 3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Finish Line
aaron thielk
1,882 Reputation
5 Guides authored
Cal Poly, Team 5-13, Maness Fall 2010 Member of Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Members
17 Guides authored
One Comment
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Reply
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 14
All Time: 9,225
