Adding a SSD or second HDD to a Asus N73J laptop.
  1. Adding a SSD or second HDD to a Asus N73J laptop., Getting access to the screws that hold the back cover in place: step 1, image 1 of 3 Adding a SSD or second HDD to a Asus N73J laptop., Getting access to the screws that hold the back cover in place: step 1, image 2 of 3 Adding a SSD or second HDD to a Asus N73J laptop., Getting access to the screws that hold the back cover in place: step 1, image 3 of 3
    • Use a small flathead screwdriver or the flat end of a spudger to gently push down the five pins just above the top row of keys that secure the keyboard to the laptop.
  2. Adding a SSD or second HDD to a Asus N73J laptop.: step 2, image 1 of 2 Adding a SSD or second HDD to a Asus N73J laptop.: step 2, image 2 of 2
    • Slowly tilt the keyboard towards the front but not too far as the flat cable is still connected.
  3. Adding a SSD or second HDD to a Asus N73J laptop.: step 3, image 1 of 2 Adding a SSD or second HDD to a Asus N73J laptop.: step 3, image 2 of 2
    • With a spudger carefully unlock the socket by pushing the white part to the left. Pull the ribbon cable straight out of its socket.
    • (For a clear view the photo shows where to push after the cable was already removed; push both from upper side as bottom side of the socket.)
  4. Adding a SSD or second HDD to a Asus N73J laptop., Removing the screws that hold the back cover in place: step 4, image 1 of 1
    • Remove these seven screws with a JIS #1 (or PH 1) to unlock the back cover.
    • Here you can see the slot for an extra RAM module.
    • When finished close the laptop and turn it over.
  5. Adding a SSD or second HDD to a Asus N73J laptop., Removing the back cover: step 5, image 1 of 3 Adding a SSD or second HDD to a Asus N73J laptop., Removing the back cover: step 5, image 2 of 3 Adding a SSD or second HDD to a Asus N73J laptop., Removing the back cover: step 5, image 3 of 3
    • Open the back cover to get access to:
    • the HDD-bays
    • the RAM modules
    • the WiFI module
  6. Adding a SSD or second HDD to a Asus N73J laptop., Preparing the SSD or HDD: step 6, image 1 of 2 Adding a SSD or second HDD to a Asus N73J laptop., Preparing the SSD or HDD: step 6, image 2 of 2
    • If you haven't done so already now is the time to mount your SSD or HDD in the caddy.
  7. Adding a SSD or second HDD to a Asus N73J laptop., Placing the SSD or HDD: step 7, image 1 of 2 Adding a SSD or second HDD to a Asus N73J laptop., Placing the SSD or HDD: step 7, image 2 of 2
    • Gently slide your new SSD/HDD in the empty HDD bay. And do not forget to secure it to the body of the laptop with a few screws.
EricV
758 Reputation
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 49
All Time: 15,188
