Introduction
To add hydraulic fluid into the tank for the BallyPal, follow the steps below:
Featured Document
To access the hydraulic tanks, use an Allen wrench to remove the two (2) screws on the main cover.
Hydraulic Fluid should not be below the MIN fluid level line.
Using a funnel, add #46 hydraulic fluid to the tank.
Do not exceed the MAX fluid level line.
Use a clean rag to wipe off any spilled or excess fluid.
Hydraulic fluid is at an acceptable level for optimal performance. Technician should perform an Operations Check to confirm unit is ready for store use.
