AcuRite 02032 Base Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. AcuRite 02032 Base Replacement, Battery: step 1, image 1 of 3 AcuRite 02032 Base Replacement, Battery: step 1, image 2 of 3 AcuRite 02032 Base Replacement, Battery: step 1, image 3 of 3
      • Remove the battery compartment lid by lifting upward.
      Ask FixBot
    2. AcuRite 02032 Base Replacement: step 2, image 1 of 1
      • Pull the ribbon to eject the 2 X AA alkaline batteries.
      Ask FixBot
    3. AcuRite 02032 Base Replacement: step 3, image 1 of 3 AcuRite 02032 Base Replacement: step 3, image 2 of 3 AcuRite 02032 Base Replacement: step 3, image 3 of 3
      • Once the batteries are removed, it is safe to proceed.
      Ask FixBot
    1. AcuRite 02032 Base Replacement, Base: step 4, image 1 of 1
      • Remove the four 0.8cm screws that attach the bottom panel to the device
      • An extended driver is needed to reach 3 of these screws. If you are using the 64 - bit driver kit you can extend the driver by inserting the driver PH1, (Phillips size 1) into the size 4 hexagonal adapter.
      Ask FixBot
    2. AcuRite 02032 Base Replacement: step 5, image 1 of 2 AcuRite 02032 Base Replacement: step 5, image 2 of 2
      • Gently lift the top section of the weather center away from the base. With all the screws removed it should lift off easily.
      Ask FixBot
Ben Kegel
350 Reputation
3 Guides authored
CSU Fullerton, Team 1-4, Bruce Fall 2016 Member of CSU Fullerton, Team 1-4, Bruce Fall 2016
CSUF-BRUCE-F16S1G4
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 197
