Introduction
Prerequisite only guide. How to separate the logic and power boards from the metal protective shield.
Lay the monitor on a flat surface, facedown.
Use a #1 Phillips screwdriver to remove the 4x 10.2mm screws securing the stand to the back panel.
Remove the stand from the back panel by pulling it up.
Remove the 2x 9.8mm Phillips #1 screws securing the back cover to the monitor.
Remove the 2 pieces of yellow tape.
The bottom one have a thin sheet a metal on the underside which you need to take off too, if it does not come off with the tape.
The button board is secured to the front frame by 2 plastic locking mechanisms.
To remove, insert a Flathead screwdriver into the gap to push the locking mechanism back a little, while pulling up on the board.
Insert a Flathead screwdriver into the holes on the top of the shield. Lodge the tip between the socket and the connector and slowly push the connector out of it's socket.
