Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement
  1. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Bottom Case: step 1, image 1 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Bottom Case: step 1, image 2 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Bottom Case: step 1, image 3 of 3
    • Turn off the laptop by holding down the power button for 7 seconds.
    • Verify that the blue power indicator light is turned off.
  2. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 2, image 1 of 2 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 2, image 2 of 2
    • Remove the plug from the back of your laptop.
    • Verify that the charging light is off after you remove the plug.
    • The battery’s charging light turns “amber” when plugged into the power cord and charging. The indicator light switches to blue once the battery is fully charged.
  3. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 3, image 1 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 3, image 2 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 3, image 3 of 3
    • Remove the eleven screws from the bottom case with a Phillips #1 Screwdriver.
  4. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 4, image 1 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 4, image 2 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 4, image 3 of 3
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • A spudger is a tool that can help separate electronic panels without scratching or damaging your device.
    • Use your thumb to apply gentle upward pressure on the laptop vent while using a spudger to separate the bottom case from the top case.
    • Work the spudger along the seam where the bottom case meets the top case.
    • Apply gentle upward pressure on the opposite laptop vent as you work the spudger across the back of the laptop.
  5. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 5, image 1 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 5, image 2 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 5, image 3 of 3
    • Turn the laptop so the laptop vents are facing away from you and the bottom case remains face up.
    • Use your fingertips to pull gently upward on the vents while using your palms to apply gentle downward pressure on the bottom case.
    • Move your hands outward from the center of the laptop to each side, continuing to pull the bottom case gently upward with your fingertips.
    • Lift the bottom case away from the laptop.
  6. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Battery: step 6, image 1 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Battery: step 6, image 2 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Battery: step 6, image 3 of 3
    • Always consider protecting against electrostatic discharge (ESD) when working on the components inside your laptop.
    • A properly grounded ESD mat and wristband can protect your laptop from ESD damage.
    • Remove the two screws securing the battery to the top case with a Phillips #0 Screwdriver.
  7. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 7, image 1 of 1
    • Lift the battery up and away from the motherboard to expose its connection wire.
  8. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 8, image 1 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 8, image 2 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 8, image 3 of 3
    • Gently remove the connection wire from the motherboard using a spudger.
    • Remove the cable only a little at a time from each side, as shown in the photos. This avoids damaging the connections.
    • Lift the disconnected battery out of the laptop.
  9. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, PCIe Solid State Drive (SSD): step 9, image 1 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, PCIe Solid State Drive (SSD): step 9, image 2 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, PCIe Solid State Drive (SSD): step 9, image 3 of 3
    • Unscrew the retaining screw that secures the SSD to the motherboard with a Phillips #0 screwdriver.
    • Ensure you are wearing a properly grounded ESD wristband before handling your SSD.
    • Gently pull your SSD out of the motherboard's PCIe slot.
    • Store your SSD on your properly grounded ESD mat while it is outside of your laptop.
  10. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 10, image 1 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 10, image 2 of 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: step 10, image 3 of 3
    • Repeat the actions you performed in the previous step to remove the SSD that is on the other side of your motherboard.
    • This slot will be empty if you have not previously upgraded your storage with an additional SSD.
Attached Documents
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 123
All Time: 747
