Using a Phillips head screw-driver remove all the screws from the rear casing of the Acer P446 Unit.
Side note: when lifting the rear cover away from the unit lift away from the VGA/HDMI Ports as the case slides into these and although you can lift it straight off you may damage the plastic
3 other people completed this guide.
