Introduction
Use this guide to replace the SSD in an Acer Nitro 5 AN517-51-56YW. The SSD is important for processing the storage on the computer, often speeding up the processing of the saved data.
Before replacing the SSD, make sure you have a compatible SSD replacement. SSDs that are non-compatible will result in an inoperative computer.
Place the laptop upside-down so that the fans are facing away from you.
Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
Pry the bottom cover away from the laptop using a spudger.
