Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Remove the 5mm screws that are securing the battery to the rest of the tablet.
Use the Phillips #00 Screwdriver to remove the 5mm screws.
Use the sharper end of the spudger to disconnect the battery from the mother board.
The battery connector will slide off.
After setting aside the battery, remove the two screws holding the metal plate over the USB port.
Disconnect the blue cable by gently lifting the flap.
Remove the indicated 2mm screw holding the speaker in place.
