This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Battery Removal: Locate the release mechanism located at the top of the compartment. Slide the lock switch to the open position to release the module, and then safely remove the dead battery by sliding it out of the chassis.
Remove the screws securing the metal bracket to the laptop chassis. Slide the drive backward to disconnect it from the data and power port. Carefully lift the device and remove it from the bay.
To remove the RAM stick, push the two metal clips securing it on the sides outward. You will see the stick pop up on its own. Once it is tilted, simply slide it out carefully, making sure not to touch the gold contacts with your fingers.
