Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement
  1. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement, LCD Screen & Digitizer Assembly: step 1, image 1 of 2 Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement, LCD Screen & Digitizer Assembly: step 1, image 2 of 2
    • Separate screen casing using a nylon spudger and a metal spudger.
  2. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: step 2, image 1 of 1
    • Peel the tape back.
    • Lift the red bar laying across the connection with the spudger.
    • Pull the connection out.
  3. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: step 3, image 1 of 2 Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: step 3, image 2 of 2
    • Disconnect the two cords shown by gently pulling them apart near their connection point.
  4. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: step 4, image 1 of 1
    • Detach the connection by gently pulling on it.
  5. Acer Chromebook Spin 11 R751TN-C5P3 LCD Screen & Digitizer Assembly Replacement: step 5, image 1 of 1
    • Unravel the cord from around the screen and lift up on the screen to remove.
To reassemble your device, follow these instructions in reverse order with new LCD screen.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 671
