Acer Chromebook R11 Wireless Card Replacement
  1. Acer Chromebook R11 Wireless Card Replacement, Wireless Card: step 1, image 1 of 1
    • Remove eleven 7.23mm Phillips #1 screws from the back panel.
    • Using a spudger, carefully separate back panel from main body.
    • The back panel is still attached to the main body by a ribbon cable. Use care not to damage the cable.
  2. Acer Chromebook R11 Wireless Card Replacement: step 2, image 1 of 1
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
    • Note the position of the black and white antenna cables on the card.
  3. Acer Chromebook R11 Wireless Card Replacement: step 3, image 1 of 1
    • Remove the single 2.85 mm Phillips #1 screw that secures the wireless card.
  4. Acer Chromebook R11 Wireless Card Replacement: step 4, image 1 of 1
    • Carefully slide the wireless card out of its socket on the motherboard.
Sean Harter
146 Reputation
1 Guide authored
USF Tampa, Team 1-2, Kass Spring 2017 Member of USF Tampa, Team 1-2, Kass Spring 2017
USFT-KASS-S17S1G2
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 27
All Time: 4,547
