Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement
  1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: step 1, image 1 of 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: step 1, image 2 of 2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 2, image 1 of 1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: step 3, image 1 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: step 3, image 2 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: step 3, image 3 of 3
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 4, image 1 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 4, image 2 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 4, image 3 of 3
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
  5. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Remove the yellow tape covering the ribbon cable in the bottom left of the motherboard as shown.
    • Carefully remove the ribbon cable out from the connector.
  6. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 6, image 1 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 6, image 2 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 6, image 3 of 3
    • Fold up the grey cover to release the ribbon cable in the bottom right of the board as shown.
    • Carefully pull out the ribbon cable from the port by the blue tape.
  7. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 7, image 1 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 7, image 2 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 7, image 3 of 3
    • Fold up the white cover to release the ribbon cable in the top left of the board as shown.
  8. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 8, image 1 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 8, image 2 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 8, image 3 of 3
    • Fold up the grey cover to release the cable on the top right of the board as shown
    • Carefully pull out the cable from the port.
  9. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 9, image 1 of 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 9, image 2 of 2
    • Remove the cable with tweezers as shown along the top of the board.
  10. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 10, image 1 of 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 10, image 2 of 2
    • Carefully pull off both brass connectors from the top left of the board with tweezers as shown.
  11. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 11, image 1 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 11, image 2 of 3 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: step 11, image 3 of 3
    • Remove the six screws from the board as shown. There are two types of screws here, so be careful to keep them separate for reassembly.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 21
All Time: 2,220
