Acer Chromebook CB3-111-C8UB Touchpad Replacement
  1. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Back Panel Removal: step 1, image 1 of 2 Acer Chromebook CB3-111-C8UB Touchpad Replacement, Back Panel Removal: step 1, image 2 of 2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 2, image 1 of 3 Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 2, image 2 of 3 Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 2, image 3 of 3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 3, image 1 of 2 Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 3, image 2 of 2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Battery: step 4, image 1 of 1
    • Locate and remove the two 6mm screws holding the battery in place with a Phillips #1 screwdriver.
  5. Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 5, image 1 of 3 Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 5, image 2 of 3 Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 5, image 3 of 3
    • Pull the battery forward to clear the base from its clips.
    • Lift the battery up so that there is room to grab and unplug the bundled cable connector.
  6. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Touchpad: step 6, image 1 of 1
    • Use a metal spudger to flip up the white ZIF connector that holds the ribbon cable in place.
    • Unplug the black ribbon cable from the track pad assembly.
  7. Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 7, image 1 of 2 Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 7, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the three 2.4mm screws located across the top of the track pad assembly.
  8. Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 8, image 1 of 1
    • Use your finger to gently pull up on the assembly and slide a metal spudger under each of the two strips of tape and peel them off of the main metal plate.
  9. Acer Chromebook CB3-111-C8UB Touchpad Replacement: step 9, image 1 of 1
    • Slide the track pad assembly up towards the motherboard until it can be lifted up and out.
Travis Vo
426 Reputation
4 Guides authored
Cal Poly, Team 22-7, Maness Winter 2017 Member of Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 1,012
