Acer Chromebook CB3-111-C8UB Key Replacement
  1. Acer Chromebook CB3-111-C8UB Key  Replacement, Key: step 1, image 1 of 3 Acer Chromebook CB3-111-C8UB Key  Replacement, Key: step 1, image 2 of 3 Acer Chromebook CB3-111-C8UB Key  Replacement, Key: step 1, image 3 of 3
    • Slide the plastic opening tool under the key you wish to remove until it is up against the bottom part of the key.
    • Then, lever the plastic opening tool. It should catch the key.
    • Finally, keep levering the key until it pops out.
    • We do this to avoid depressing the key. It becomes much harder to catch the lip with the key pushed down.
Travis Vo
426 Reputation
4 Guides authored
Cal Poly, Team 22-7, Maness Winter 2017 Member of Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 453
