Acer Chromebook CB3-111-C670 Keyboard Key Replacement
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: step 1, image 1 of 1
    • Use a plastic opening tool or spudger and gently insert it in between the crevice of the key.
    • Begin carefully prying the key from each side until it is easily removed by hand.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: step 2, image 1 of 1
    • Once the key is completely removed, you can insert the new key by laying it on top of the empty key and pressing down until you hear it "click" in place.
Tony
459 Reputation
2 Guides authored
USF Tampa, Team 10-5, Remmell Spring 2016 Member of USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Members
8 Guides authored
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 66
All Time: 7,325
