Introduction
If the motherboard for your Acer Chromebook (model C731-C8VE) is damaged, defective, or requires replacement for some other reason, this guide will help you to do so with ease.
Before removing the motherboard, you must remove cables that connect to peripheral components and the screws that hold the motherboard in place. Afterwards, removing the motherboard is as simple as lifting it out of place.
You will of course need to ensure that your laptop is completely powered off and not connected to a source of power to avoid risk of electrocution or other injury.
Using tweezers, carefully disconnect the I/O board ribbon cable from the motherboard.
