Introduction
The battery wears out over time, causing the device to not hold a charge. By replacing the battery, it will increase the length of use between charges.
On the underside of the laptop towards the back, locate the battery lock slider. Push the slider, and remove the battery.
Almost done!
You listed “spudger” under Tools, but you show a Prying Tool in the images.
Patty Remmell - Reply
