Acer Chromebook C710 RAM Replacement
  1. Acer Chromebook C710 RAM Replacement, Battery: step 1, image 1 of 2 Acer Chromebook C710 RAM Replacement, Battery: step 1, image 2 of 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710 RAM Replacement: step 2, image 1 of 2 Acer Chromebook C710 RAM Replacement: step 2, image 2 of 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710 RAM Replacement, Acer Chromebook C710-2847 Back Cover Replacement: step 3, image 1 of 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710 RAM Replacement: step 4, image 1 of 2 Acer Chromebook C710 RAM Replacement: step 4, image 2 of 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710 RAM Replacement, RAM: step 5, image 1 of 2 Acer Chromebook C710 RAM Replacement, RAM: step 5, image 2 of 2
    • Pull the metal tabs sideways away from the memory stick.
    • The RAM stick will pop up.
  6. Acer Chromebook C710 RAM Replacement: step 6, image 1 of 2 Acer Chromebook C710 RAM Replacement: step 6, image 2 of 2
    • Pull the RAM stick up and away from the laptop.
Bradley Pavy
1,257 Reputation
6 Guides authored
Cal Poly, Team 13-3, Forte Fall 2013 Member of Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 31
All Time: 13,196
