Introduction
Use this guide to replace the speakers.
Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
Sixteen 5mm Phillips screws located around the border.
Two 5mm Phillips screws located in center.
Carefully eject the black ribbon from the white base by squeezing inward at the base and gently pulling backwards.
Gently pull black ribbon out.
Almost done!
