Introduction
This guide will show you how to replace the internal battery of the Acer Aspire V5-552PG-X469. This replacement may be necessary if the device won't turn on or charge even after being plugged into its charger for several minutes. Be sure to fully power off and unplug the device before beginning the battery replacement.
Parts
No parts required.
  1. Use a J0 JIS screwdriver to remove 17 7mm screws from the back case. They can be located on the underside of the device. Use a J0 JIS screwdriver to remove 17 7mm screws from the back case. They can be located on the underside of the device.
    • Use a J0 JIS screwdriver to remove 17 7mm screws from the back case. They can be located on the underside of the device.
  2. Remove the plastic tab on the left edge of the device.
    • Remove the plastic tab on the left edge of the device.
  3. Lift up the back case to remove it. Lift up the back case to remove it.
    • Lift up the back case to remove it.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  5. Pull to remove the multicolor bundled cable connector from its input. Pull to remove the multicolor bundled cable connector from its input.
    • Pull to remove the multicolor bundled cable connector from its input.
  6. Pull to remove the small black bundled cable with a white connector from its input on the left side. Pull to remove the black bundled cable with a black connector from its input on the left side. Pull to remove the black bundled cable with a black connector from its input on the left side.
    • Pull to remove the small black bundled cable with a white connector from its input on the left side.
    • Pull to remove the black bundled cable with a black connector from its input on the left side.
  7. Use a  2.0 flathead screwdriver to unscrew the 4mm screw from the center of the battery. Use a  2.0 flathead screwdriver to unscrew the 4mm screw from the center of the battery.
    • Use a 2.0 flathead screwdriver to unscrew the 4mm screw from the center of the battery.
  8. Lift up the battery to remove it. Be careful not to bend the battery while lifting it out, as this may cause a fire hazard.
    • Lift up the battery to remove it.
    • Be careful not to bend the battery while lifting it out, as this may cause a fire hazard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 234
