Acer Aspire V5-552PG-X469 Battery Replacement
  1. Acer Aspire V5-552PG-X469 Battery Replacement, Back Case: step 1, image 1 of 1
    • Remove the storage tray on the left edge of the device.
  2. Acer Aspire V5-552PG-X469 Battery Replacement: step 2, image 1 of 1
    • Use a Phillips #0 screwdriver to remove seventeen 7mm screws from the lower case.
  3. Acer Aspire V5-552PG-X469 Battery Replacement: step 3, image 1 of 1
    • Lift up the back case to remove it.
  4. Acer Aspire V5-552PG-X469 Battery Replacement, Battery: step 4, image 1 of 2 Acer Aspire V5-552PG-X469 Battery Replacement, Battery: step 4, image 2 of 2
    • Pull the battery connector away from the hard drive to disconnect it from its socket.
  5. Acer Aspire V5-552PG-X469 Battery Replacement: step 5, image 1 of 3 Acer Aspire V5-552PG-X469 Battery Replacement: step 5, image 2 of 3 Acer Aspire V5-552PG-X469 Battery Replacement: step 5, image 3 of 3
    • Pull the white connector toward the battery to disconnect it.
    • Pull the black tape-wrapped connector toward the battery to disconnect it.
  6. Acer Aspire V5-552PG-X469 Battery Replacement: step 6, image 1 of 2 Acer Aspire V5-552PG-X469 Battery Replacement: step 6, image 2 of 2
    • Remove the PH #0 screw from the center of the battery.
  7. Acer Aspire V5-552PG-X469 Battery Replacement: step 7, image 1 of 2 Acer Aspire V5-552PG-X469 Battery Replacement: step 7, image 2 of 2
    • Lift up the battery to remove it.
    • Be careful not to bend the battery while lifting it out, as this may cause a fire hazard.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,257
