Acer Aspire V5-122P-0468 Network Card Replacement
  1. Acer Aspire V5-122P-0468 Network Card Replacement, Battery: step 1, image 1 of 2 Acer Aspire V5-122P-0468 Network Card Replacement, Battery: step 1, image 2 of 2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Network Card Replacement: step 2, image 1 of 2 Acer Aspire V5-122P-0468 Network Card Replacement: step 2, image 2 of 2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Network Card Replacement: step 3, image 1 of 2 Acer Aspire V5-122P-0468 Network Card Replacement: step 3, image 2 of 2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Network Card Replacement: step 4, image 1 of 3 Acer Aspire V5-122P-0468 Network Card Replacement: step 4, image 2 of 3 Acer Aspire V5-122P-0468 Network Card Replacement: step 4, image 3 of 3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Network Card Replacement: step 5, image 1 of 3 Acer Aspire V5-122P-0468 Network Card Replacement: step 5, image 2 of 3 Acer Aspire V5-122P-0468 Network Card Replacement: step 5, image 3 of 3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Network Card Replacement, Network Card: step 6, image 1 of 1
    • Remove the wire connector from the network card using a plastic opening tool.
  7. Acer Aspire V5-122P-0468 Network Card Replacement: step 7, image 1 of 1
    • Remove 3 mm long Phillips head screw using PH0 screwdriver
  8. Acer Aspire V5-122P-0468 Network Card Replacement: step 8, image 1 of 1
    • Gently slide Network Card out of motherboard connector.
Nat McCormick
801 Reputation
5 Guides authored
USF Tampa, Team S16-G1, Boczar Spring 2018 Member of USF Tampa, Team S16-G1, Boczar Spring 2018
USFT-BOCZAR-S18S16G1
5 Members
10 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 16
All Time: 557
