Acer Aspire S7-392-6484 Solid State Drive Replacement
  1. Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: step 1, image 1 of 2 Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: step 1, image 2 of 2
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Acer Aspire S7-392-6484 Solid State Drive Replacement: step 2, image 1 of 2 Acer Aspire S7-392-6484 Solid State Drive Replacement: step 2, image 2 of 2
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  3. Acer Aspire S7-392-6484 Solid State Drive Replacement, Solid State Drive: step 3, image 1 of 1
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  4. Acer Aspire S7-392-6484 Solid State Drive Replacement: step 4, image 1 of 1
    • Remove the hard drive by pulling it away horizontally from its connection.
3 other people completed this guide.
Nicholas Wise
754 Reputation
5 Guides authored
USF Tampa, Team S2-G6, Eyestone Spring 2018 Member of USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 2,610
