Acer Aspire R7-371T-72CF Wifi Chip Replacement
  1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: step 1, image 1 of 2 Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: step 1, image 2 of 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 2, image 1 of 1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 3, image 1 of 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 3, image 2 of 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 3, image 3 of 3
    • Locate the wifi chip, as shown to the left.
    • The chip can by identified by the white and black wires connected to it, as well as a single screw holding it in place.
  4. Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 4, image 1 of 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 4, image 2 of 3 Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 4, image 3 of 3
    • Locate the 2 antenna wires connected to the chip.
    • One is black, and the other is white.
    • Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
    • The connectors 'click' into place, like a button.
  5. Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 5, image 1 of 2 Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 5, image 2 of 2
    • Remove the Phillips #00 6mm securing screw using your screwdriver.
  6. Acer Aspire R7-371T-72CF Wifi Chip Replacement: step 6, image 1 of 1
    • Remove the chip by pulling towards the edge of the computer.
2 other people completed this guide.
Dylan Meintser
476 Reputation
4 Guides authored
Cal Poly, Team S8-G5, Banghart Fall 2017 Member of Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Members
5 Guides authored
One Comment
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
Hasan Mahmood - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 543
