Acer Aspire R7-371T-72CF Hard Drive Replacement
  1. Acer Aspire R7-371T-72CF Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Acer Aspire R7-371T-72CF Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Hard Drive Replacement: step 2, image 1 of 1
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Hard Drive Replacement: step 3, image 1 of 3 Acer Aspire R7-371T-72CF Hard Drive Replacement: step 3, image 2 of 3 Acer Aspire R7-371T-72CF Hard Drive Replacement: step 3, image 3 of 3
    • Locate the hard drive, as shown to the left. This can be identified by its location underneath the cooling fan and above the ribbon cable (the long horizontal white strip).
  4. Acer Aspire R7-371T-72CF Hard Drive Replacement: step 4, image 1 of 2 Acer Aspire R7-371T-72CF Hard Drive Replacement: step 4, image 2 of 2
    • Remove the Phillips #00 4mm securing screw using your screwdriver.
  5. Acer Aspire R7-371T-72CF Hard Drive Replacement: step 5, image 1 of 1
    • Remove the hard drive by pulling towards the side that was secured by the screw.
Dylan Meintser
476 Reputation
4 Guides authored
Cal Poly, Team S8-G5, Banghart Fall 2017 Member of Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,899
