Acer Aspire R7-371T-72CF Battery Replacement
  1. Acer Aspire R7-371T-72CF Battery Replacement, Battery: step 1, image 1 of 2 Acer Aspire R7-371T-72CF Battery Replacement, Battery: step 1, image 2 of 2
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Battery Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Battery Replacement: step 3, image 1 of 3 Acer Aspire R7-371T-72CF Battery Replacement: step 3, image 2 of 3 Acer Aspire R7-371T-72CF Battery Replacement: step 3, image 3 of 3
    • Remove the Phillips #00 5mm securing screws using your screwdriver.
  4. Acer Aspire R7-371T-72CF Battery Replacement: step 4, image 1 of 2 Acer Aspire R7-371T-72CF Battery Replacement: step 4, image 2 of 2
    • Disconnect the battery from the motherboard by simply pulling the wires down towards the battery until the adapter dislodges.
Dylan Meintser
476 Reputation
4 Guides authored
Cal Poly, Team S8-G5, Banghart Fall 2017 Member of Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 2,945
