Acer Aspire R5-571T-59DC Motherboard Replacement
  1. Acer Aspire R5-571T-59DC  Motherboard Replacement, Back Cover Panel: step 1, image 1 of 2 Acer Aspire R5-571T-59DC  Motherboard Replacement, Back Cover Panel: step 1, image 2 of 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: step 2, image 1 of 3 Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: step 2, image 2 of 3 Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: step 2, image 3 of 3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC  Motherboard Replacement, Hard Drive: step 3, image 1 of 1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC  Motherboard Replacement: step 4, image 1 of 1
    • Lift the hard drive up and out of the laptop.
  5. Acer Aspire R5-571T-59DC  Motherboard Replacement, Fan: step 5, image 1 of 1
    • Remove the seven 0.7mm Phillips #00 screws securing the fan in place.
  6. Acer Aspire R5-571T-59DC  Motherboard Replacement: step 6, image 1 of 1
    • Unplug fan from motherboard.
    • Lift and remove fan from case.
  7. Acer Aspire R5-571T-59DC  Motherboard Replacement, RAM: step 7, image 1 of 1
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  8. Acer Aspire R5-571T-59DC  Motherboard Replacement: step 8, image 1 of 3 Acer Aspire R5-571T-59DC  Motherboard Replacement: step 8, image 2 of 3 Acer Aspire R5-571T-59DC  Motherboard Replacement: step 8, image 3 of 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
  9. Acer Aspire R5-571T-59DC  Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Remove the nine 0.7mm Phillips #00 screws from the motherboard.
  10. Acer Aspire R5-571T-59DC  Motherboard Replacement: step 10, image 1 of 1
    • Use a spudger to flip up the retaining flaps on all of the ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
    • Lift up and remove the motherboard.
Kelly Johnston
600 Reputation
4 Guides authored
USF Tampa, Team S20-G2, Passmore Spring 2018 Member of USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,905
