Acer Aspire One D257 Keyboard Replacement
  1. Acer Aspire One D257 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Put the netbook, so the back side is upwards.
  2. Acer Aspire One D257 Keyboard Replacement: step 2, image 1 of 1
    • Push the right lock to the right so the red filed is visible on the left.
  3. Acer Aspire One D257 Keyboard Replacement: step 3, image 1 of 1
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  4. Acer Aspire One D257 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Acer Aspire One D257 Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
  5. Acer Aspire One D257 Keyboard Replacement: step 5, image 1 of 1
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
5 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Claes
3,400 Reputation
6 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,468 Guides authored
One Comment
I lost the flat retaining of the keyboard, what can I use?
ciccio - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 1,967
