Acer Aspire One D257 HDD Replacement
  1. Acer Aspire One D257 HDD Replacement, Battery: step 1, image 1 of 1
    • Put the netbook, so the back side is upwards.
  2. Acer Aspire One D257 HDD Replacement: step 2, image 1 of 1
    • Push the right lock to the right so the red filed is visible on the left.
  3. Acer Aspire One D257 HDD Replacement: step 3, image 1 of 1
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  4. Acer Aspire One D257 HDD Replacement, Keyboard: step 4, image 1 of 2 Acer Aspire One D257 HDD Replacement, Keyboard: step 4, image 2 of 2
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
  5. Acer Aspire One D257 HDD Replacement: step 5, image 1 of 1
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
  6. Acer Aspire One D257 HDD Replacement, Acer Aspire One D257 opening the hatch: step 6, image 1 of 1
    • Remove the 5 screws marked with "Door".
  7. Acer Aspire One D257 HDD Replacement: step 7, image 1 of 2 Acer Aspire One D257 HDD Replacement: step 7, image 2 of 2
    • Use a spudger or flat screwdriver to push down the hatch where it is marked "Door release".
    • Now you can carfully remove the hatch.
    • When reassembling the hatch look that the noses are aimed at the appropriate holes in the case, then you can press down the rest of the hatch onto the netbook.
  8. Acer Aspire One D257 HDD Replacement, Harddisk Drive: step 8, image 1 of 1
    • The hard disk drive is under the lighgrey casing and not screw to it.
  9. Acer Aspire One D257 HDD Replacement: step 9, image 1 of 1
    • Now push the HDD downwards with the finger through the hole.
  10. Acer Aspire One D257 HDD Replacement: step 10, image 1 of 1
    • Remove the Sata connector from the hard disk drive.
    • Now you can connect any Sata-HDD or SDD.
7 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Claes
3,400 Reputation
6 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,535 Guides authored
7 Comments
very helpful
many thanks
Pablo Tassinari - Reply
You are missing a few steps.
Arctic W. Fox - Reply
@Arctic W. Fox What steps are you missing?
Claes - Reply
The HD is removed through the back - there are about 5 screws (marked "Door") that need to be removed once the keyboard is removed. :-)
basestationzero - Reply
Thanks for the feedback, I added the steps at least in the German Guide do not know how long it takes for the steps to show up in the translated English Version.
Claes -
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 37
All Time: 11,695
