Introduction
The USB port allows you to connect other devices to the laptop. This guide will show you how to remove and replace the USB port.
Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
Using the plastic opening tool, lift the white tab 90 degrees releasing the ribbon cable.
Lightly tug on the ribbon cables to remove it from its slot.
Remove the 5mm Phillips head screw with the PH0 screw driver head.
Remove the USB port from the device.
