Acer Aspire ES1-332 LCD Screen Replacement
Video Overview
  1. Acer Aspire ES1-332 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Acer Aspire ES1-332 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Acer Aspire ES1-332 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Grab a spudger and work your way around the outer edge of the screen
    • Lean the screen all the way back to remove the plastic frame from the hinges at the bottom
  2. Acer Aspire ES1-332 LCD Screen Replacement: step 2, image 1 of 2 Acer Aspire ES1-332 LCD Screen Replacement: step 2, image 2 of 2
    • Unscrew the 4 screws around the edge of the screen
    • Lean the screen all the way forward on to the keyboard
  3. Acer Aspire ES1-332 LCD Screen Replacement: step 3, image 1 of 2 Acer Aspire ES1-332 LCD Screen Replacement: step 3, image 2 of 2
    • Peal up the sticky tape next to the screen connector
    • Pull the connector down carefully away from the screen and disconnect it
  4. Acer Aspire ES1-332 LCD Screen Replacement: step 4, image 1 of 3 Acer Aspire ES1-332 LCD Screen Replacement: step 4, image 2 of 3 Acer Aspire ES1-332 LCD Screen Replacement: step 4, image 3 of 3
    • connect the new screen and screw back in place
    • Turn on the screen to test before putting the screen frame back on
    • Tilt the screen all the way back and push the frame back on hinges 1st.
    • Finally lean the laptop on its edge and clip the back on the hinges back in place.
Nick Myers
3,501 Reputation
25 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 689
