Acer Aspire E5-573G Hard Drive Replacement
  1. Acer Aspire E5-573G Hard Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Hard Drive Replacement: step 2, image 1 of 1
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Acer Aspire E5-573G Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Unscrew all 17 (5mm) Philips head screws from the bottom.
    • Unscrew the 3 (2.5mm) Philips head screws underneath the optical drive.
  4. Acer Aspire E5-573G Hard Drive Replacement: step 4, image 1 of 2 Acer Aspire E5-573G Hard Drive Replacement: step 4, image 2 of 2
    • Run a pick around the edge of the laptop (between the two parts) to open it.
    • Lift the left side of the case up and unplug the speaker cable before fully taking the bottom off.
  5. Acer Aspire E5-573G Hard Drive Replacement: step 5, image 1 of 1
    • Remove the hard drive by pulling it out to the left.
Alex Bahm
2,232 Reputation
6 Guides authored
Cal Poly, Team S12-G5, Banghart Winter 2018 Member of Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Members
15 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 56
All Time: 9,089
