This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Acer Aspire 5750 RAM module replacement
    1. Acer Aspire 5750 RAM module replacement, Open the cover hiding the RAM: step 1, image 1 of 3 Acer Aspire 5750 RAM module replacement, Open the cover hiding the RAM: step 1, image 2 of 3 Acer Aspire 5750 RAM module replacement, Open the cover hiding the RAM: step 1, image 3 of 3
      • Use a Phillips screwdriver to remove the two (highlighted) screws from the main cover.
      • Now use a spudger to remove the cover by applying a little pressure.
      Ask FixBot
    2. Acer Aspire 5750 RAM module replacement, Removing the RAM modules: step 2, image 1 of 3 Acer Aspire 5750 RAM module replacement, Removing the RAM modules: step 2, image 2 of 3 Acer Aspire 5750 RAM module replacement, Removing the RAM modules: step 2, image 3 of 3
      • Now towards the right we will see the RAM modules, which are blue or green.
      • We will see tabs that hold the modules in place, so, still using the flat end of a spudger, we will move them outwards.
      • Perform the same step with the module underneath.
      Ask FixBot
    3. Acer Aspire 5750 RAM module replacement, Removing the RAM cards: step 3, image 1 of 2 Acer Aspire 5750 RAM module replacement, Removing the RAM cards: step 3, image 2 of 2
      • Use your hands or a pair of tweezers to remove the RAM cards from the connector.
      Ask FixBot
    4. Acer Aspire 5750 RAM module replacement, Positioning the new cards: step 4, image 1 of 3 Acer Aspire 5750 RAM module replacement, Positioning the new cards: step 4, image 2 of 3 Acer Aspire 5750 RAM module replacement, Positioning the new cards: step 4, image 3 of 3
      • Reposition the new cards at an angle.
      • Applying a little pressure with your finger, push the card down until it clicks into place and you hear a metallic "click."
      Ask FixBot
    5. Acer Aspire 5750 RAM module replacement, Reinstalling the bracket: step 5, image 1 of 3 Acer Aspire 5750 RAM module replacement, Reinstalling the bracket: step 5, image 2 of 3 Acer Aspire 5750 RAM module replacement, Reinstalling the bracket: step 5, image 3 of 3
      • To reassemble, fit the bracket back into place and reinstall the screws, and you're done.
      Ask FixBot
Finish Line
Ema.exe
538 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 64
All Time: 338
