Acer Aspire 5742G Memory stick Replacement
Video Overview
click here for video
  1. Acer Aspire 5742G Memory stick Replacement, Memory stick: step 1, image 1 of 1
    • Make sure your computer is off and remove the battery with the security tabs shown in the picture
  2. Acer Aspire 5742G Memory stick Replacement: step 2, image 1 of 1
    • Remove these philips screws, only two :)
  3. Acer Aspire 5742G Memory stick Replacement: step 3, image 1 of 2 Acer Aspire 5742G Memory stick Replacement: step 3, image 2 of 2
    • Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
    • Easily work your way around.
    • WARNING! PLASTIC TABS! be careful not to break them!
  4. Acer Aspire 5742G Memory stick Replacement: step 4, image 1 of 1
    • Now you've removed the cover, you will get access to your Antenna, HDD, and RAM
    • Please remove both tabs with the memory stick at the same time
  5. Acer Aspire 5742G Memory stick Replacement: step 5, image 1 of 1
    • Now put the new memory stick in!
    • When it is in, then gently push it downwards to lock it in place!
    • Be aware you have to line up the stick with a pin in the socket!!
Petter Berget
740 Reputation
3 Guides authored
Kid fixers Member of Kid fixers
Community
158 Members
295 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 770
