Acer Aspire 5536 Display Replacement
  1. Acer Aspire 5536 Display Replacement, Display: step 1, image 1 of 1
    • Remove the 4 rubber supports from the screen. Then remove the screws underneath.
  2. Acer Aspire 5536 Display Replacement: step 2, image 1 of 2 Acer Aspire 5536 Display Replacement: step 2, image 2 of 2
    • With a spudger, release the clips that hold the plastic frame to the back cover.
    • Be careful while handling the bottom part, specially with the hinges, as there are cables inside.
  3. Acer Aspire 5536 Display Replacement: step 3, image 1 of 1
    • When all the clips are out, the entire plastic frame should come out easily.
  4. Acer Aspire 5536 Display Replacement: step 4, image 1 of 2 Acer Aspire 5536 Display Replacement: step 4, image 2 of 2
    • Carefully disconnect the camera cable.
  5. Acer Aspire 5536 Display Replacement: step 5, image 1 of 2 Acer Aspire 5536 Display Replacement: step 5, image 2 of 2
    • Remove the 4 screws located in the sides of the LCD screen.
  6. Acer Aspire 5536 Display Replacement: step 6, image 1 of 1
    • Remove the other 4 screws that secure the metal LCD frame to the hinges.
  7. Acer Aspire 5536 Display Replacement: step 7, image 1 of 3 Acer Aspire 5536 Display Replacement: step 7, image 2 of 3 Acer Aspire 5536 Display Replacement: step 7, image 3 of 3
    • Take the LCD screen out of the metal frame and flip it towards the keyboard.
  8. Acer Aspire 5536 Display Replacement: step 8, image 1 of 2 Acer Aspire 5536 Display Replacement: step 8, image 2 of 2
    • Remove the tape that holds the display cable.
    • Be careful not to take the entire tape away, as this may cause severe damage to the cable.
  9. Acer Aspire 5536 Display Replacement: step 9, image 1 of 2 Acer Aspire 5536 Display Replacement: step 9, image 2 of 2
    • Carefully disconnect the cable with a spuger.
  10. Acer Aspire 5536 Display Replacement: step 10, image 1 of 2 Acer Aspire 5536 Display Replacement: step 10, image 2 of 2
    • Unstick the cables from the back of the LCD screen.
    • The LCD should be completely free, so just take it out and install a new one.
TechStem
461 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 5
All Time: 6,872
