This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Acer Aspire 5315 Disassembly
    1. Acer Aspire 5315 Disassembly, Hard Drive Teardown: step 1, image 1 of 2 Acer Aspire 5315 Disassembly, Hard Drive Teardown: step 1, image 2 of 2
      • The hard drive is inside that compartment.
      • To take out the hard drive, remove the screws and pull backwards to remove it.
      Ask FixBot
    2. Acer Aspire 5315 Disassembly, Remove the cover: step 2, image 1 of 2 Acer Aspire 5315 Disassembly, Remove the cover: step 2, image 2 of 2
      • To be able to disassemble the components, we must first remove the cover.
      • To remove the cover, we will have to unscrew the following screws that are marked in the first image
      Ask FixBot
    3. Acer Aspire 5315 Disassembly, Remove the dead battery: step 3, image 1 of 2 Acer Aspire 5315 Disassembly, Remove the dead battery: step 3, image 2 of 2
      • To remove the dead battery we have to remove the safe, and pull the other lever and it will go out alone.
      Ask FixBot
    4. Acer Aspire 5315 Disassembly, Remove the floppy drive: step 4, image 1 of 2 Acer Aspire 5315 Disassembly, Remove the floppy drive: step 4, image 2 of 2
      • To remove the floppy drive we have to unscrew the screw is in the compartment where the motherboard.
      • In the image 1 the screw to be removed is marked.
      Ask FixBot
    5. Acer Aspire 5315 Disassembly, Remove the RAM stick: step 5, image 1 of 3 Acer Aspire 5315 Disassembly, Remove the RAM stick: step 5, image 2 of 3 Acer Aspire 5315 Disassembly, Remove the RAM stick: step 5, image 3 of 3
      • To be able to remove the RAM stick, next to it there are two levers (Image1)
      • In order to remove it, we have to press the two levers out simultaneously (Image2)
      • To take it out you must be in a diagonal position because if not, it can break or become damaged.
      Ask FixBot
    6. Acer Aspire 5315 Disassembly, Remove and clean the cooling fan: step 6, image 1 of 3 Acer Aspire 5315 Disassembly, Remove and clean the cooling fan: step 6, image 2 of 3 Acer Aspire 5315 Disassembly, Remove and clean the cooling fan: step 6, image 3 of 3
      • To remove the cooling fan, we have to unscrew it and disconnect it from the board. (In image 1 it is marked where the screws and the connector are)
      • Then to open it we have to remove the screws that are behind (in Image 2 they are marked)
      • After it is open we can use a can of compressed air for its cleaning.
      Ask FixBot
    7. Acer Aspire 5315 Disassembly, Remove the heatsink: step 7, image 1 of 2 Acer Aspire 5315 Disassembly, Remove the heatsink: step 7, image 2 of 2
      • Now that we have removed the cooling fan, we must remove the heatsink.
      • To remove the heatsink we have to unscrew the screws that are marked in Image 1
      Ask FixBot
    8. Acer Aspire 5315 Disassembly, Remove the processor: step 8, image 1 of 2 Acer Aspire 5315 Disassembly, Remove the processor: step 8, image 2 of 2
      • To remove the processor we must be very careful, since if you do not remove it well, the pins can break.
      • To be able to remove the processor we will need a screwdriver, and we will have to unscrew this screw. (image 1)
      • When it is already loosened we have to remove the processor upwards so that no pin breaks
      Ask FixBot
    9. Acer Aspire 5315 Disassembly, Remove the WI-FI card: step 9, image 1 of 2 Acer Aspire 5315 Disassembly, Remove the WI-FI card: step 9, image 2 of 2
      • To remove the Wi-Fi card, the first thing we need to remove is the two cables and the two screws that are marked in Image 1
      • When we have already removed both cables and screws, the card will come out on its own; we must be careful and pull it out diagonally so it does not break.
      Ask FixBot
    10. Acer Aspire 5315 Disassembly, Remove the keyboard: step 10, image 1 of 2 Acer Aspire 5315 Disassembly, Remove the keyboard: step 10, image 2 of 2
      • To remove the keyboard, we have to press four tabs that are marked in Image 1.
      • In order to press the tabs, we will use a flat-head screwdriver or lever.
      Ask FixBot
To Reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos Ibañez
315 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 116
All Time: 2,513
