Acer Aspire 5315 Assembly Replacement
  1. Acer Aspire 5315 Assembly Replacement, Assemble the keyboard: step 1, image 1 of 2 Acer Aspire 5315 Assembly Replacement, Assemble the keyboard: step 1, image 2 of 2
    • To mount the keyboard, put the keypad and press until it clicks
  2. Acer Aspire 5315 Assembly Replacement, Mount the network card: step 2, image 1 of 2 Acer Aspire 5315 Assembly Replacement, Mount the network card: step 2, image 2 of 2
    • To mount the network card, we have to put it diagonally if it can not be broken.
    • When it is already on, it is only necessary to adjust the screw.
    • To connect the two cables we have to put it on their sites and press until one click.
  3. Acer Aspire 5315 Assembly Replacement, Mount the processor: step 3, image 1 of 2 Acer Aspire 5315 Assembly Replacement, Mount the processor: step 3, image 2 of 2
    • To mount the processor, what we have to do is put it straight, if the pins break, it will no longer work.
    • When it is well placed, we only have to adjust the screw until it is well fixed.
  4. Acer Aspire 5315 Assembly Replacement, Mount the heat sink: step 4, image 1 of 2 Acer Aspire 5315 Assembly Replacement, Mount the heat sink: step 4, image 2 of 2
    • To mount the heatsink, we have to take good care of it, and if the processor could not be reheated, it would be wrong.
    • When it is well put put the four screws to fix it.
    • Set the heatsink to the fan.
  5. Acer Aspire 5315 Assembly Replacement, Mount the fan: step 5, image 1 of 2 Acer Aspire 5315 Assembly Replacement, Mount the fan: step 5, image 2 of 2
    • When it is already cleaned, we return the four screws to it so that it does not open.
    • Then we place it in its place on the motherboard and fix it.
    • We do not forget to connect the cable.
  6. Acer Aspire 5315 Assembly Replacement, Put RAM memory: step 6, image 1 of 2 Acer Aspire 5315 Assembly Replacement, Put RAM memory: step 6, image 2 of 2
    • To place the RAM we have to be careful that it can also be broken as the network card
    • We have to put it diagonally so it does not break.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos Ibañez
231 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 8
All Time: 394
